GatorMitch
Dec 22, 2025Aspirant
Orbi 370 Satellite Speed is bad
I thought I was upgrading from my RBR50 and 1 satellite that died by getting the Orbi 370 and 1 satellite. Wow was I wrong. I have 500 speed fiber. Wireless that sees the router gets great speed, ...
GatorMitch
Thanks for the link. When I read the features for the 370 it says it has enhanced backhaul (MLO). Are you saying it doesn't have a dedicated backhaul to connect the satellite to the router? I can't figure out if any other similar priced set up has a dedicated backhaul.
Dec 23, 2025Guru - Experienced User
GatorMitch wrote:Are you saying it doesn't have a dedicated backhaul to connect the satellite to the router?
It does not.
FWIW, high-end WiFi 7 routers have three client bands - 2.4 ghz, 5 ghz, and 6 ghz. They are trending away from a dedicated backhaul network, since the extra 6 ghz band adds enough bandwidth to allow running the backhaul over the same radios.
Is the backhaul to your satellite using 5 Ghz? Also, do you know what band the client is connecting with?
