hollenhoes
May 26, 2026Follower
Orbi 370 satellites not pushing past 40-50mbps while main router is getting 1000+mbps
I'd like to preference this by saying I'm not super internet savvy. But I recently purchased a orbi 370 mesh system with 2 satellites. I am getting amazing output from my main router at around 1000+ ...
May 26, 2026Guru - Experienced User
How are you speed testing at the RBS? Wired PC or wireless device? If wireless need to be sure that the device is connected at the RBS and not at the RBR.
Brand and model# of wifi devices your using?
Building materials can impact wifi signals between the RBR and RBS.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
Armor, Smart Parental Controls or Circle, IPv6, Traffic Meter.
