AlkiMojo
Sep 23, 2025Aspirant
Orbi 370 vs Orbi 360?
I am starting to see an Orbi 360 package (RBE363) that looks exactly like the Orbi 370. See: https://www.amazon.com/dp/B0FLKMNW1B
Does anyone know what the difference is? It costs less so I am wondering if there is a small change in chipsets.
Thanks
Odd, as I am not seeing it on http://www.netgear.com or in the Netgear storefront on Amazon.
So no idea on the model number, or the $50 price difference.
Been told there the same. Not sure why of the model number change. Both availabe thru Amazon.
Do I remember correctly that YEARS ago Netgear produced special models for sale by Costco that were the same as other products, only packaged with a different model number?
The 360 may be a 370 available only through Amazon.
I've often seen this with Costco and Best Buy - though mostly with Arlo products, which of course is now divested. So I'm guessing that is the case here, but it still should be listed in the support pages. Hopefully it will show up soon.
Searching for "Orbi 360" site:www.netgear.com doesn't work, you get a lot of hits talking about 360 degree coverage with other Orbi models. So not the best branding decision.
- AlkiMojoAspirant
I see Netgear just posted the technical specs for the 360: https://www.netgear.com/support/product/rbe360/#docs
Compared to the 370 specs, the 360 specs omit mention of the quad-core 1.5Ghz processor and the high-performance antennas with power amplifiers.
