n810l33
Jul 23, 2026Aspirant
Orbi 370 Wired Ethernet Throttled to 200 Mbps (Wi-Fi reaches 600 Mbps)
Hello, I am looking for help troubleshooting a persistent speed bottleneck on my Netgear Orbi 370 Wi-Fi 7 Mesh System. My ISP is Hawaiian Telcom Fiber (900 Mbps download). The Orbi App speed tes...
n810l33
Jul 24, 2026Aspirant
Thank you the PC is connected to the directly to the router.
Jul 25, 2026Guru - Experienced User
n810l33 wrote:Thank you the PC is connected to the directly to the router.
OK.
You said above that this happened on multiple LAN ports. The router has only one LAN port. Is there a switch connected to that port? Or did you mean you've tested this on both the router and one of the satellites? If not, it would be useful to test on the satellite LAN ports, and see if you get a faster download speed.
Do you have a switch handy? If the PC is directly connected to the LAN port, then it would be useful to see if inserting a switch between the PC and the router helps. The LAN port is multigig, so it is possible something is going wrong with the speed negotiation.
Also, are you using cat 6 cables? If not, then what are you using?
HappyCat wrote:The only method available to users is to download the firmware images for router and satellite from the web site, unpack them, and then use the Manual Update process on the web interface. (satellites first, router last)
The most recent firmware for the router and satellites is here:
I doubt that the firmware is the issue, but there are security fixes, so you should update it. Note the firmware for the satellites is different from the router (and the update will fail if you accidentally install the wrong one).
- n810l33Jul 26, 2026Aspirant
Thank you yes I'm using cat 5e cables but I plugged directly to the Modem and got 900 Mbps so I don't think its the cable. I've updated the firmware now but the speeds are still low. Yes I know the router only has one LAN port I don't have a switch though.
- StephenBJul 27, 2026Guru - Experienced User
This could also be a failed NIC in the router. If you are still within the seller's return period you could try exchanging the Orbi system.
Can you try a ping test from the windows cmd line? (ping -n 600 1.1.1.1). That will take 10 minutes to complete, and will give you some idea on packet loss.
You might consider picking up a small gigabit switch for testing - as they are inexpensive ($20 USD or less), and often are useful.
- n810l33Jul 28, 2026Aspirant
I don't have a gigabit switch for testing but I ran the ping -n 600 1.1.1.1 test and it showed
Ping statistics for 1.1.1.1:
Packets: Sent = 600, Received = 600, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 2ms, Maximum = 39ms, Average = 4ms
