n810l33
Jul 23, 2026Aspirant
Orbi 370 Wired Ethernet Throttled to 200 Mbps (Wi-Fi reaches 600 Mbps)
Hello, I am looking for help troubleshooting a persistent speed bottleneck on my Netgear Orbi 370 Wi-Fi 7 Mesh System. My ISP is Hawaiian Telcom Fiber (900 Mbps download). The Orbi App speed tes...
n810l33
Jul 24, 2026Aspirant
ISP Modem is a NOKIA XS-101X-Q
Firmware is v12.1.3.11
Yes this does happen with multiple PCs
Yes drivers are updated.
QoS and gaming features disabled
Yes using Ookla speed test
Jul 25, 2026Guru - Experienced User
What speed results do you see with the speed test on the RBRs web page and using Orbi app on a mobile device?
What speeds do you see with a Ethernet PC directly connected to the Nokia ONT?
What brand and model# are the ethernet adapters in these PCs?
n810l33 wrote:ISP Modem is a NOKIA XS-101X-Q
- n810l33Jul 26, 2026Aspirant
RBR and Orbi app show 900 Mbps upload and 600 Mbps download which is what is expected. This is also the speed when plugged into the Nokia ONT directly as well. Not sure on brand and model # of ethernet adapters but given speeds shown plugged into the modem itself I don't think it is the problem.
