piddyy
Oct 07, 2025Tutor
Orbi 770 – WiFi Drops Every Hour
At the beginning of the year, I posted in this forum about hourly interruptions with my ORBI770 mesh system. At the time, other users were experiencing similar problems, and I worked with Netgear Sup...
Oct 08, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Armor, Smart Parental Controls or Circle, IPv6, Traffic Meter.
My 770 series is back online and is stable for me. Been solid on v.3. FW and prior. Had it online for around 20+ days back in July.
- piddyyOct 08, 2025Tutor
- V10.5.20.3What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
- Sunrise ISP Switzerland Connect Box 3 Modem (DOCSIS 3.1)Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
- Yes, tested also other cable, same issue.How many RBS are deployed?
- 220 square meter, around 2400 square ft
- 4 floors
- 1 router and 2 satellite with more than 30 feet distance between RBR / RBS
- Not sureDoes this happen with both wireless and wired devices?
- Only wirelessWhat channel configurations are currently set on the router?
- Different configs (48, Auto but also 40, 5)Any Wifi Neighbors near by? If so, how many?
- no
- All disabled except IPv6
- Can I disable this over Advanced - IPv6 - Internet Connection Type - Disabled?Has a factory reset and setup from scratch been performed since last FW update?
- Yes, nothing changed.- FURRYe38Oct 08, 2025Guru - Experienced User
For that size of home, the RBR and just one RBS would be needed. Can you try with turning OFF one of the RBS for now?
Please see if the all RBS turned OFF if this still happens with the RBR alone.
Try channels 1 and 40 or 11 and 48.
Yes to disable IPv6.
How long have you had this system for?
No, unfortunately not. With only two devices, I have poor coverage. But yes, I can test it when I switch off the satellites.
I got the system in January and the problem since then.
