piddyy
Oct 07, 2025Tutor
Orbi 770 – WiFi Drops Every Hour
At the beginning of the year, I posted in this forum about hourly interruptions with my ORBI770 mesh system. At the time, other users were experiencing similar problems, and I worked with Netgear Sup...
piddyy
Oct 08, 2025Tutor
- V10.5.20.3
- Sunrise ISP Switzerland Connect Box 3 Modem (DOCSIS 3.1)
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
- Yes, tested also other cable, same issue.
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite🛰
- 220 square meter, around 2400 square ft
- 4 floors
- 1 router and 2 satellite with more than 30 feet distance between RBR / RBS
Does this happen with the RBS turned OFF?
- Not sure
Does this happen with both wireless and wired devices?
- Only wireless
What channel configurations are currently set on the router?
- Different configs (48, Auto but also 40, 5)
- no
Armor, Smart Parental Controls or Circle, IPv6, Traffic Meter.
- All disabled except IPv6
- Can I disable this over Advanced - IPv6 - Internet Connection Type - Disabled?
- Yes, nothing changed.
Oct 08, 2025Guru - Experienced User
For that size of home, the RBR and just one RBS would be needed. Can you try with turning OFF one of the RBS for now?
Please see if the all RBS turned OFF if this still happens with the RBR alone.
Try channels 1 and 40 or 11 and 48.
Yes to disable IPv6.
How long have you had this system for?
- piddyyOct 08, 2025Tutor
No, unfortunately not. With only two devices, I have poor coverage. But yes, I can test it when I switch off the satellites.
I got the system in January and the problem since then.
- FURRYe38Oct 08, 2025Guru - Experienced User
Ok.
Let us know the results of the RBR alone.
If you have been seeing this since then, I recommend opening up a support ticket with NG and check on RMA options.
Have you read my text? Of course, after such a long time, I have an open support ticket, unfortunately without success.
