piddyy
Oct 08, 2025Aspirant
Orbi 770 – WiFi Drops Every Hour
At the beginning of the year, I posted in this forum about hourly interruptions with my ORBI770 mesh system. At the time, other users were experiencing similar problems, and I worked with Netgear Sup...
CrimpOn
Oct 09, 2025Guru - Experienced User
Thanks for responding. Would it be convenient to post those actual debug log messages from 08:03:10 to 8:03:20?
piddyy wrote:WiFi connections to both the router and satellites are affected the same way?
No, just the devices connected to the router
Please confirm that the RBE771 WAN port is connected directly to the ISP device and one of the RBE771 LAN ports is connected to the unmanaged switch.
- piddyyOct 10, 2025Aspirant
The ISP modem is connected directly to the WAN port and the router is connected to the unmanaged switch with the LAN port.
Yes, I can publish these log messages, but there are many lines. I have to upload them as a PDF here, as I cannot select txt files.
I also copied a few seconds before and after and anonymised the MAC addresses. I hope that no other sensitive information is included.
