piddyy
Oct 07, 2025Tutor
Orbi 770 – WiFi Drops Every Hour
At the beginning of the year, I posted in this forum about hourly interruptions with my ORBI770 mesh system. At the time, other users were experiencing similar problems, and I worked with Netgear Sup...
Austin_Netgear1
Oct 22, 2025NETGEAR Expert
Hi piddyy ,
Could you please try disabling IPv6 and changing the Automatic Channel Selection to a fixed channel to see if that fixes the issue? We’d like to check if these settings are related to the problem.
Please refer to the following screenshots.
Austin
piddyy
Oct 22, 2025Tutor
Hi Austin,
Thank you for your message. I had already disabled IPv6 and changed the channel selection. Unfortunately, this did not help.
- Austin_Netgear1Oct 22, 2025NETGEAR Expert
Hi piddy,
Thank you for the update and for testing those changes.
We appreciate your time and the detailed feedback.
Our team will continue to investigate this behavior further to identify the root cause.
We’ll provide you with an update as soon as more information becomes available.Austin
- Austin_Netgear1Nov 19, 2025NETGEAR Expert
Hi piddyy
I’ve sent you a direct message with some details about your Orbi case.
Please take a look when you have a moment — thank you for your cooperation!Austin
