pbokeefe1027
Aug 25, 2026Aspirant
Orbi 770 + ATT BGW620-700 IPV6
Does anybody have a working configuration that allows IPV6 to leave home and reach public internet? ATT Gateway -> Home Network -> IPV6 IPv6: On DHCPv6: On DHCPv6 Prefix Delegation: On Router...
Aug 25, 2026Guru - Experienced User
Maybe due to your gateway already being a router.
Try disabling IPv6 on the ATT router and leave IPv6 enabled on the RBR. Try using DHCP for IPv6.
Ask the ISP what mode you should use on the RBR.
Try enabling IPv6 on the ATT router then change the RBR to AP mode.
