wmdmoyer
May 10, 2025Tutor
Orbi 770 Essentially Not Working
At this point, my Orbi 770 is almost unusable. After 5 months, I started having serious problems. I can't reliably connect to my work VPN, my family is regularly seeing internet connection problem...
wmdmoyer
May 10, 2025Tutor
Some additional detail. I have the latest firmware. While my work VPN (Global Protect) will not reliably connect, McAfee VPN works reliably. When I connect to McAfee VPN on my personal laptop, all of the problems reliably go away.
May 11, 2025Guru - Experienced User
So you only have issues when the work VPN is connected?
