RickinNY
Sep 05, 2026Aspirant
Orbi 770 has become unusable with my Fios system. Constant drops of internet
I have not changed anything from what was a stable set up last week. To best of my knowledge fios router is still in passive mode - with Orbi doing all the worker, but it frequently drops internet. L...
Sep 05, 2026Guru - Experienced User
RickinNY wrote:Old 500 series was way more stable for us.
Can you give us more details on what model that was?
RickinNY wrote:To best of my knowledge fios router is still in passive mode
Do you mean you set up the fios router in IP passthrough? Or something else?
RickinNY wrote:Loses connection multiple times per day (red from router back to internet).
This could be cabling. The 770 has a 2.5 gpbs WAN port, and the current Fios routers have 2.5 gbps LAN. If the cable between them can't reliably handle that speed, you will see connection drops.
The patch cable between them should be at least CAT 6. If there is a lot of other cabling nearby, then shielded Cat 6 (STP) might help.
If you have a small gigabit switch handy, you could also put that in between the Fios router and the Orbi. If that resolves the problem, then that points to the cabling not being able to carry 2.5 gbps reliably.
Keep in mind this also applies to the cabling between the fios router and the ONT.
RickinNY
Thanks spent an hour with Fios... they had me "hard reset" and confirmed that all radios on Fios Router were off.... Still seeing drops - ordered cat8 cord for tomorrow, will see if that helps.
This is a NEW feature on my orbi system. Constant disconnecting
- StephenBSep 05, 2026Guru - Experienced User
This is a NEW feature on my orbi system. Constant disconnectingFWIW, I also use Verizon Fios, together with my Orbi 870 system. I am not seeing the connection drops that you are seeing.
Both devices are routing (192.168.1.x for the Fios Lan, 10.0.0.x for the Orbi LAN) - so I am using a double-NAT configuration. WiFi on the Verizon router is turned off, and IPv6 is disabled in the Orbi. WiFi is provided to their set top boxes using an older Orbi (RBK50) that is in AP mode and connected to the Fios LAN.
If you are only using their internet service, you could try connecting the 770 router directly to the ONT.
- KevinLiTSep 07, 2026NETGEAR Moderator
Hello RickinNY ,
Welcome to the NETGEAR Community!
I understand that you are having intermediate network connection issues with your RBE771 and your Fios system. To mitigate this issue, please update your RBE771 to our latest firmware release version 12.1.7.23.
Navigate to the link below for the download file for your RBE771:
https://www.netgear.com/support/product/rbe772v2
For step-by-step instructions on how to manually update your RBE771 please navigate to the link below:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-comBest,
Kevin
NETGEAR Team
- RickinNYSep 07, 2026Aspirant
Kevin - is this for routers or sats? And why doesnt the app not choose this upgrade when i check for updates
- FURRYe38Sep 08, 2026Guru - Experienced User
Make sure first that you have a 770v2 series. The v12 FW posted by the moderator is NOT compatible with the 770v1 series. There are two different HW revisions. v1 and v2. Both have different FW versions.
Hello RickinNY ,
The link (https://www.netgear.com/support/product/rbe772v2) has the most current available firmware for the router and the satellite. This is shown as "(Orbi Router) and (Orbi Satellite)" next to the perspective firmware options. Firmware 12.1.7.23 is currently being sent out in small batches before mass release.
Best,
Kevin
NETGEAR Team
