RickinNY
Sep 05, 2026Aspirant
Orbi 770 has become unusable with my Fios system. Constant drops of internet
I have not changed anything from what was a stable set up last week. To best of my knowledge fios router is still in passive mode - with Orbi doing all the worker, but it frequently drops internet. L...
RickinNY
Thanks spent an hour with Fios... they had me "hard reset" and confirmed that all radios on Fios Router were off.... Still seeing drops - ordered cat8 cord for tomorrow, will see if that helps.
This is a NEW feature on my orbi system. Constant disconnecting
KevinLiT
Sep 07, 2026NETGEAR Moderator
Hello RickinNY ,
Welcome to the NETGEAR Community!
I understand that you are having intermediate network connection issues with your RBE771 and your Fios system. To mitigate this issue, please update your RBE771 to our latest firmware release version 12.1.7.23.
Navigate to the link below for the download file for your RBE771:
https://www.netgear.com/support/product/rbe772v2
For step-by-step instructions on how to manually update your RBE771 please navigate to the link below:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
Best,
Kevin
NETGEAR Team
- RickinNYSep 07, 2026Aspirant
Kevin - is this for routers or sats? And why doesnt the app not choose this upgrade when i check for updates
- FURRYe38Sep 08, 2026Guru - Experienced User
Make sure first that you have a 770v2 series. The v12 FW posted by the moderator is NOT compatible with the 770v1 series. There are two different HW revisions. v1 and v2. Both have different FW versions.
- RickinNYSep 09, 2026Aspirant
Thanks for the warning. App doesn't show which version... Is there a way to tell?
I am finding this generation of Netgear stuff pretty unsatisfying and the UX and Support not the best..
And I loved the last gen and have been Netgear for more than a decade
- KevinLiTSep 07, 2026NETGEAR Moderator
Hello RickinNY ,
The link (https://www.netgear.com/support/product/rbe772v2) has the most current available firmware for the router and the satellite. This is shown as "(Orbi Router) and (Orbi Satellite)" next to the perspective firmware options. Firmware 12.1.7.23 is currently being sent out in small batches before mass release.
Best,
Kevin
NETGEAR Team
