PedroA
May 29, 2026Tutor
Orbi 770, ipv6, Gigaclear - works then drops
I'm trying to get my Orbi 770 to have a stable ipv6 connection with my ISP Gigaclear. Initially it works, then it doesn't. The Orbi 770 is running Firmware Version V10.5.20.10_2.2.51 My conne...
ceebee6cc
Aug 11, 2026Tutor
That’s good to hear; no change here but a different model (the 870) and my firmware version is an older revision than you’re showing, so they may get around to fixing mine in a few months ~:)
| Router | RBE871 | RBE871 | V10.5.20.4_1.3.5 | No new firmware version available. |
Aug 11, 2026Guru - Experienced User
Give same configuration as this users configuration while on same ISP. If it doesn't work, you'll need to keep IPv6 disabled until next FW update appears for your 870 series.
