lunik
Jul 23, 2025Tutor
Orbi 770 keeps disconnecting Smart Home devices even with 2.4 GHz
Just installed the Orbi 770 with 2 satellites to completely cover the house. IoT WiFi is enabled with 2.4 GHz only. All the smart home devices (Ring cameras, Google Home, etc) when connected will hav...
CrimpOn
Jul 24, 2025Guru - Experienced User
lunik wrote:Is there an advanced setting I am overlooking or is this a defective product?
There is no advanced setting. Once a device connects to WiFi, it stays connected until it decides to disconnect.
I suspect the Smart Home environment may be affecting individual device behavior. What happens if a device that is prone to network disconnection is removed from Smart Home?
lunik wrote:Just installed the Orbi 770 with 2 satellites
Does this mean that this system remains within the magic 90 days of 'complimentary support'?
