netheadgear1
Jan 08, 2026Follower
Orbi 770 keeps disconnecting
I got an Orbi 770 with two satellites for 800$+ 8 months back (RBE770/RBE771). I got it imagining that this is a high end product and will give me stable Wi-Fi and connectivity for my whole home. It ...
Jan 09, 2026Guru - Experienced User
What is the size of the home in sq feet?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet is starting distance or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
Does this happen with the RBS turned OFF?
What channel configurations are currently set on the router?
Did you perform the factory reset and setup from scratch after newest FW had been loaded?
netheadgear1 wrote:I got an Orbi 770 with two satellites for 800$+ 8 months back (RBE770/RBE771). I got it imagining that this is a high end product and will give me stable Wi-Fi and connectivity for my whole home. It was all good for the first two and a half months, then the issues started popping. All my devices started seeing random Wi-Fi disconnects multiple times a day. I suspect it happens during the transition point between my router and satellite but I'm not sure. My phone for example keeps disconnecting and reconnecting often even when I'm in the same place on my bed. I followed all the troubleshooting steps that I can find online and in Reddit and simply am unable to fix the issue. The Orbi app says that I cannot reach out to customer care or create an online support case for this issue. I feel like Netgear is holding me hostage after taking 850 plus dollars. So, out of desperation to make my router work and since I cannot afford another router I am reaching out to this community for help fix my Wi-Fi.
Below are all the troubleshooting steps that I've tried but I still have random Wi-Fi disconnects:
Use Wi-Fi backhaul to connect all three router+2sats. (Tried this to eliminate any issues with ethernet cable)
Use ethernet cables , my house had it wired to connect all three devices. ( Tried this to eliminate any issues with Wi-Fi connectivity between devices)
Confirm that the three devices are at least 40 ft apart from each other.(General recommendation I see online)
Use only two devices, one router one satellite. ( Just another test in case my router and satellites are close to each other, Made sure they are at least 50 plus feet apart.
Use multiple phones ( to double check it's not my phone specific issue)
Restarted my phone, laptop, router, satellites multiple times.
Factory reset my Orbi router and satellites
Update to latest firmware
Disable IPv6
Revert firmware version to v10.5.18.3 (some reddit threads mention this version to be functional and fixing issues)
Confirmed there is no VPN on phone.
Disabled Mac randomizer on phone and devices
All about did not fix my issue and I don't have hope on being able to reach Netgear for help. Can someone from this community help me in this issue?
Is it in hardware issue or some bad software update?
