Malvada
Jun 17, 2025Aspirant
Orbi 770 lag spikes and disconnects
Hi, I recently purchased an Orbi 770 mesh system. Unfortunately I have a virgin media 5x and as such have had to try a number of workarounds to get them both to work. Currently the Orbi router i...
Malvada
Jun 18, 2025Aspirant
Hi,
The house is no bigger that 1600 Sq. ft.
I have tried disabling the virgin router Wi-Fi channels but this does not improve the issues with the Orbi.
The issues are still there if the Orbi is in router or AP mode.
The virgin router does not have a modem mode. It is the Hub 5x. Some people say it has but have tried setting it up multiple times but the Orbi cannot connect to anything even after several reboots and resets.
I will contact NG about the beta firmware, seems crazy really as the speed I am getting near the PS5 wirelessly if fast but its the constant lag spikes which is annoying whilst gaming or the TV system disconnecting several times over a short period
Have even thought about the TP link Deco BE65 BE9300 but i have had an Orbi mesh system previously and it was excellent.
Jun 18, 2025Guru - Experienced User
Others reported having issues with lag spikes while connected behind the RBS.
Hoping the beta FW will change this.
1600 sq ft, hoping the RBS is out at 30 feet or a bit more. 1600sq feet the RBR alone could work well.
