MRRioVista
May 19, 2026Aspirant
ORBI 770 Mesh Add On Satellite
Does anyone know when the ORBI 770 Mesh Add-On Satellite will be back in stock? (BE11000 Mesh WiFi Satellite (RBE770)) Thanks, RIO
- May 20, 2026
Terrific!!! Must have just been made available.
Problem solved.
Thanks,
Rio
MRRioVista
Since the ORBI 770 Mesh Add-On Satellite is out of stock. Will using the Nighthawk WiFi 7 Dual-Band Extender (BE5000 WiFi 7 Extender (EXS27)) have any negative impacts on my 770 Mesh network? I am not sure whether the two products can work together without degrading each other.
So it's adding an extender to a mesh network.
Thanks,
Rio
May 19, 2026Guru - Experienced User
The extender could work, in a pinch or last resort kind of thing, however won't integrate into the system like actual RBS will. Might give Amazon a go and see if that works for you.
MRRioVista wrote:Since the ORBI 770 Mesh Add-On Satellite is out of stock. Will using the Nighthawk WiFi 7 Dual-Band Extender (BE5000 WiFi 7 Extender (EXS27)) have any negative impacts on my 770 Mesh network? I am not sure whether the two products can work together without degrading each other.
Thanks,
Rio
