MRRioVista
May 19, 2026Aspirant
ORBI 770 Mesh Add On Satellite
Does anyone know when the ORBI 770 Mesh Add-On Satellite will be back in stock? (BE11000 Mesh WiFi Satellite (RBE770)) Thanks, RIO
- May 20, 2026
Terrific!!! Must have just been made available.
Problem solved.
Thanks,
Rio
MRRioVista
Since the ORBI 770 Mesh Add-On Satellite is out of stock. Will using the Nighthawk WiFi 7 Dual-Band Extender (BE5000 WiFi 7 Extender (EXS27)) have any negative impacts on my 770 Mesh network? I am not sure whether the two products can work together without degrading each other.
So it's adding an extender to a mesh network.
Thanks,
Rio
donawalt
May 19, 2026Hero - Experienced User
I use an extender in my garage area to my 970 mesh network. It works well. Speeds are not the same, but for my purposes they are perfectly fine.My iPhone will get 200-300 Mbps d/l there, whereas nearby an Orbi it will get 1300-1400 Mbps. But that's fine for the garage, to have coverage. That's acceptable for almost anything I can think of, and we have at most 2 devices on it at any time - not like the devices connecting to an Orbi route or satellite.
The extender shows in your device list, but any devices attached to it do not. It does support being on the same SSID so devices will flip to it automatically. Not a bad solution, probably the cost-effective alternative. I have the AX1600.
https://www.amazon.com/dp/B099GLVBGP?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1&th=1
