Redcenta
Sep 25, 2026Initiate
Orbi 770 satellite drops clients when IOT or Guest networks are activated
I’ve a 770 mesh system with router and one satellite. It’s V1 hardware running the latest (10.5.20.10) firmware. Repeated tests confirm that the satellite stops serving all connected clients (bo...
Sep 26, 2026Guru - Experienced User
Does this happen if the RBS are not connected and just the RBR running?
5m is too close from the RBR to RBS. 10m is starting distance in between the RBR and RBS and each other.
- RedcentaSep 27, 2026Initiate
It’s just the satellite that drops clients. The router appears to work as expected when IOT / Guest networks are enabled.
Distance of RBS from RBR doesn’t seem to affect outcomes. Same problem occurs at separations of both 5m & 20m.
I’m guessing it’s a firmware bug - but would be interesting to know if anyone else is seeing this problem.
- schumakuSep 27, 2026Guru - Experienced User
Reads to me like the the config change enabling IoT and/or Guest network is not deployed correctly to the satellite or satellites.
KevinLiT any ideas?
- FURRYe38Sep 28, 2026Guru - Experienced User
Does this happen to both Wireless and Ethernet connected devices at the RBS?
I have my 770v1 series online currently and checking for this.
I’m guessing it’s a firmware bug - but would be interesting to know if anyone else is seeing this problem. - FURRYe38Sep 30, 2026Guru - Experienced User
Just to update, I've reproduced this on my 770v1 series.
Feedback results given to NG. Hopefully they can get it fixed before next FW update. Not idea when that maybe.
For now, I recommend not using IoT and Guest Network until fix appears.
Please be patient.
- RedcentaSep 30, 2026Initiate
Thanks very much FURRYe38 for taking the time / frustration to undertake the experiment / confirm the outcome :) Extremely helpful.
Hopefully corrected in the not-too-distant future.
