Redcenta
Sep 25, 2026Initiate
Orbi 770 satellite drops clients when IOT or Guest networks are activated
I’ve a 770 mesh system with router and one satellite. It’s V1 hardware running the latest (10.5.20.10) firmware. Repeated tests confirm that the satellite stops serving all connected clients (bo...
Sep 27, 2026Guru - Experienced User
Redcenta wrote:Repeated tests confirm that the satellite stops serving all connected clients (both wired and wireless) soon after either of the Guest or IOT networks are activated. At this time the router status page indicates that the satellite is connected (both 5ghz & 6ghz) but the connections of all satellite clients are greyed out / disconnected.
Can you access the satellite web page from a client connected to the router when this happens?
Browse to satellite-ip/status (using the real satellite ip address of course)
