Redcenta
Sep 25, 2026Initiate
Orbi 770 satellite drops clients when IOT or Guest networks are activated
I’ve a 770 mesh system with router and one satellite. It’s V1 hardware running the latest (10.5.20.10) firmware. Repeated tests confirm that the satellite stops serving all connected clients (bo...
Redcenta
Sep 27, 2026Initiate
It’s just the satellite that drops clients. The router appears to work as expected when IOT / Guest networks are enabled.
Distance of RBS from RBR doesn’t seem to affect outcomes. Same problem occurs at separations of both 5m & 20m.
I’m guessing it’s a firmware bug - but would be interesting to know if anyone else is seeing this problem.
schumaku
Sep 27, 2026Guru - Experienced User
Redcenta wrote:It’s just the satellite that drops clients. The router appears to work as expected when IOT / Guest networks are enabled.
Reads to me like the the config change enabling IoT and/or Guest network is not deployed correctly to the satellite or satellites.
KevinLiT any ideas?
