Redcenta
Sep 25, 2026Initiate
Orbi 770 satellite drops clients when IOT or Guest networks are activated
I’ve a 770 mesh system with router and one satellite. It’s V1 hardware running the latest (10.5.20.10) firmware. Repeated tests confirm that the satellite stops serving all connected clients (bo...
FrumpyGrandpa
Sep 27, 2026Luminary
Redcenta wrote:the only way to recover reliable operation of the satellite appears to be
After the Factory Reset and configuration, how long does the system function normally? i.e. does it fail immediately when either the Guest of IoT WiFi networks is enabled?
