orbiisweaksauce
May 06, 2025Aspirant
Orbi 770s wheres the transmit power option?
The documentation says there should be an option to control transmit power. Number 1 rule of setting up wifi is balancing the power transmission. Just because my device can hear the router screaming...
- May 08, 2025
Yes it was scrapped before launch.
Most of the User manuals are templates for all Orbi systems and not really tuned for each Orbi model. Ya they should be. Orbi AC, AX and AXE have the power controls which reflects in the UM. BE systems don't. I don't think NG will bring it back. Unless it's a major issue causing problems for lots of users, I wouldn't look for it to return.
May 07, 2025Guru - Experienced User
Orbi BE systems have never had power adjustments. Was removed before they released.
Also it's up to devices to pick and choose where they connect too. Some devices will not lock on to a stronger signal even though there locked on to a weaker signal. How they handle that is on the Device Mfr. User can force this by disconnecting or disabling the wifi radio on the device for 5 seconds then re-enable it and usually the device will lock on to the stronger signal.
orbiisweaksauce
May 07, 2025Aspirant
I have around 60 IoT devices/lights/cameras all around the house it would be infeasible to have to go and physically power them off and on 1 by 1 unfortunately. Imagine if the Orbi had a simple disconnect client option to force it from the GUI, but for a company that can't even let you control the power I know that is far too much to ask. Maybe I'll have to hook up one of my enterprise APs and mark the IoT SSID as rogue AP to punt all the devices off temporarily.
