orbiisweaksauce
May 06, 2025Aspirant
Orbi 770s wheres the transmit power option?
The documentation says there should be an option to control transmit power. Number 1 rule of setting up wifi is balancing the power transmission. Just because my device can hear the router screaming...
- May 08, 2025
Yes it was scrapped before launch.
Most of the User manuals are templates for all Orbi systems and not really tuned for each Orbi model. Ya they should be. Orbi AC, AX and AXE have the power controls which reflects in the UM. BE systems don't. I don't think NG will bring it back. Unless it's a major issue causing problems for lots of users, I wouldn't look for it to return.
May 07, 2025Guru - Experienced User
Even the main netgear one still shows it in there. I've had the rbe773 since release and haven't seen transmit power controls
- orbiisweaksauceMay 07, 2025Aspirant
So seems to me this is an oversight that they need to fix.
- KevinLiTMay 08, 2025NETGEAR Moderator
Hello orbiisweaksauce ,
Welcome to the NETGEAR Community!
I understand that you would like to manage the transmission power on your RBE771/770. Unfortunately, Transmit Power control is not available on the Wi-Fi 7 Orbi Mesh systems.
Best,
Kevin
Community Team
