nomadz02
Aug 06, 2026Follower
Orbi 771 blocking websites
Orbi 771 firmware 10.5.20.10 suddenly blocking websites i use for work. websites worked yesterday and today they are being blocked on anything using wifi. i disconnected my phone and website works fi...
Aug 06, 2026Guru - Experienced User
The issue is between the host site and the WAF. Web Application Firewall. Not the router.
Is this the first time seeing this issue while connected to the Orbi system?
Happens if you use ISP IPv4 detected DNS?
Is IPv6 enabled or disabled on the RBR?
Brand and model# of the ISP modem that the RBR is connected too?
Might check with your works IT group for help and information regarding accessibility to work sites.
