nomadz02
Aug 06, 2026Follower
Orbi 771 blocking websites
Orbi 771 firmware 10.5.20.10 suddenly blocking websites i use for work. websites worked yesterday and today they are being blocked on anything using wifi. i disconnected my phone and website works fi...
HappyCat
Aug 06, 2026Luminary
nomadz02 wrote:when i go to HOME there is an orange circle around it
It would be really helpful to see a screen capture of this.
It appears the application (??) is using a proxy server. Is there a specific reason for this?
- StephenBAug 07, 2026Guru - Experienced User
This is not under nomadz02's control. The website (www.avigilon.com) uses a web application firewall hosted by incapsula. Remember that nomadz02 is connecting to their employer's remote access portal.
The WAF makes whitelisting a bit tricky, since the connection goes to the WAF, and not directly to the website. But the unlimited (unmanaged) profile should work as long as the router is seeing the real MAC address of the PC.
nomadz02: If you are using a Windows PC, then make sure it is classifying the wifi network as "private". Windows will sometimes rotate the MAC address on public networks (depending on the PC settings).
FURRYe38 wrote:
Might check with your works IT group for help
Agree - likely they have seen this before. They can also look at their logs, which would giv more information.
