manusjuhl
Sep 28, 2026Tutor
Orbi 772 backhaul through MoCa
Hi everyone, I hope someone can help point me in the right direction, because both I (and Copilot, Gemini, and ChatGPT) have run out of ideas. I recently purchased a new mesh system (Netgear Orb...
FrumpyGrandpa
Sep 28, 2026Apprentice
Is it possible to have the TP-Link and the Orbi router in the same room? If so, can you try:
- TP-Link LAN port to Orbi router WAN port.
- Orbi router LAN port to MoCA adapter
- Orbi satellite LAN port to MoA adapter
Orbi systems expect to "see" satellites connected to the router LAN ports, not to the router WAN port.
Yes, if the coax cable is being used only for the data network, then replace that 6-port splitter with a simple coax connector to make the router to satellite coax a single length with no splitters.
- manusjuhlSep 28, 2026Tutor
I will try tomorrow - I can put all of them in the same room.
not sure if I understand the last bit. It’s important for me that the Orbi router is not placed where my fiber modem because of the general Wi-Fi coverage.
B Manus
