manusjuhl
Sep 28, 2026Tutor
Orbi 772 backhaul through MoCa
Hi everyone, I hope someone can help point me in the right direction, because both I (and Copilot, Gemini, and ChatGPT) have run out of ideas. I recently purchased a new mesh system (Netgear Orb...
manusjuhl
Sep 28, 2026Tutor
Hi Plemans,
It’s non powered.
the model is Trix 349806 SCS-6.
MoCa are gocoax MD2500D.
Br Manus
Sep 28, 2026Guru - Experienced User
Those are solid moca adapters. I'd try the removing the splitter for now. If that works, it might be worth checking into an approved 6x powered moca adapter.
- manusjuhlSep 28, 2026Tutor
I will try that, but it will mean that (for the test) that only one of the Orbi is online, right?
- plemansSep 28, 2026Guru - Experienced User
Just for testing purposes. Once you figure out if that stays stable, it helps you understand if the issues is the moca or not.
I have just ordered a MoCa specific 2 way splitter (I dont need more for the house). I will keep you posted.
