manusjuhl
Sep 28, 2026Tutor
Orbi 772 backhaul through MoCa
Hi everyone, I hope someone can help point me in the right direction, because both I (and Copilot, Gemini, and ChatGPT) have run out of ideas. I recently purchased a new mesh system (Netgear Orb...
FrumpyGrandpa
Sep 28, 2026Apprentice
Great solution, schumaku . With a single coax cable running from the splitter location to Room 1 (with the Orbi router), there will be two MoCA adapters connected in Room 1.
- One MoCA adapter set to the D-Band Low connected to the Orbi router WAN port. (with the other D-Band Low connected to the TP-Link.
- One MoCA adapter set to the D-Band High connected to one of the Orbi router LAN ports. (with the other D-Band High connected to the Orbi satellite LAN port).
