Giovanni_L
Jun 26, 2025Guide
Orbi 772 Satellite disconnects
At the end of last November, I started a thread about a problem I was experiencing with the Orbi satellite I had just purchased as part of an RBE772 system (Internet access frequently dropped at Orbi...
- Jul 16, 2025
I will mark it as solved, but I don't know if it is completely true. As they say, absence of evidence is not evidence of absence... or, it is hard to prove a negative.
It is a fact that I have not had the same Internet disconnects issue so far, after 3 weeks, so that may be cause of optimism
Jun 26, 2025Guru - Experienced User
I had my 773 series online earlier this year and hadn't seen any issues with RBS failing to get internet and devices connected at the RBS. Others haven't posted recently of having issues with there RBS. I know there were some having issues at the RBS cauing bad latency every hour. Something I could not reproduce with my system while I had it online.
I see there is newer FW for the 870 series which the 770 series should be on case base code so I'd expect something for the 770 past v.18.3...Just not sure if or when anything newer will appear.
Something to give another try.
