Giovanni_L
Jun 26, 2025Guide
Orbi 772 Satellite disconnects
At the end of last November, I started a thread about a problem I was experiencing with the Orbi satellite I had just purchased as part of an RBE772 system (Internet access frequently dropped at Orbi...
- Jul 16, 2025
I will mark it as solved, but I don't know if it is completely true. As they say, absence of evidence is not evidence of absence... or, it is hard to prove a negative.
It is a fact that I have not had the same Internet disconnects issue so far, after 3 weeks, so that may be cause of optimism
Jul 15, 2025Guru - Experienced User
Any progress on this?
