Giovanni_L
Jun 26, 2025Guide
Orbi 772 Satellite disconnects
At the end of last November, I started a thread about a problem I was experiencing with the Orbi satellite I had just purchased as part of an RBE772 system (Internet access frequently dropped at Orbi...
- Jul 16, 2025
I will mark it as solved, but I don't know if it is completely true. As they say, absence of evidence is not evidence of absence... or, it is hard to prove a negative.
It is a fact that I have not had the same Internet disconnects issue so far, after 3 weeks, so that may be cause of optimism
Giovanni_L
Jul 16, 2025Guide
Jul 16, 2025Guru - Experienced User
Well if the new system is working past what the old system was doing and your not longer experiencing the same issues as before and has been working well for you, then I would call it solved. Kinda points to possible faulty 1st system and your 2nd system seems to resolve that.
Overall glad the 2nd system is working for you.
