Giovanni_L
Jun 26, 2025Guide
Orbi 772 Satellite disconnects
At the end of last November, I started a thread about a problem I was experiencing with the Orbi satellite I had just purchased as part of an RBE772 system (Internet access frequently dropped at Orbi...
- Jul 16, 2025
I will mark it as solved, but I don't know if it is completely true. As they say, absence of evidence is not evidence of absence... or, it is hard to prove a negative.
It is a fact that I have not had the same Internet disconnects issue so far, after 3 weeks, so that may be cause of optimism
Giovanni_L
Jul 16, 2025Guide
Just one more comment from me: I now don't believe the first system had any hardware problems.
Instead, I think the problem was fixed in the following FW release 10.5.18.3, which was available by the time I bought the second system.
I just could not take the risk with the first system, as I was up to the 30-day window to return it and I did not know if and when a new FW would fix it.
