sjw70's avatar
sjw70
Orbi 870 - Netgear device already registered with another account
Hello,
In the Orbi app I am trying to enable Anywhere Access for my Netgear Orbi 870 system, but I receive the message: “This Netgear device is already registered with another account.”
I only have one Netgear account and in My Products I can see the Orbi within that account. There is no option to remove or deregister the device as far as I can see.
What could I do to make sure my product is only registered by myself and to enable anywhere access?
Note: I have the Orbi app installed on two iPhones with the same Netgear account.
Thanks in advance.
SJW
  • Would dearly love to have an explanation, but fear there simply isn't one.
    Unless the ISP connection requires a login (which few do), Orbi systems do not require configuration.  Factory Reset, plug it in, and use the WiFi credentials printed on the label.  Most of us prefer to customize the configuration, which requires either using the web interface or the Orbi 'app'.  The web interface, does not require that the router be registered with Netgear.
    To use the Orbi 'app', an email address registered with Netgear must be entered using the password associated with that address.  However, the Orbi router does not have to be registered to this account for the app to connect.  (I just verified this by connecting an Android tablet to an RBR750 that is not registered to me (or anyone as far as I know).  The app connected and I can see the tablet as an Attached Device.  Anywhere Access is already enabled.  I then disabled and enabled Anywhere Access.  I then disconnected the tablet from this RBR750 router and connected it to my primary home WiFi network.  Opened the Orbi 'app' and it immediately connected to the RBR750 using Anywhere Access.
    This leads to a suspicion that the error message “This Netgear device is already registered with another account.” is ambiguous.  What it might mean is, "This Netgear device has been configured for Anywhere Access using a different Netgear login."  Since the error message does not display the conflicting information, there is no clue as to whether
    • It is an entirely different person, or
    • There is perhaps one character in the email or password field that is different.  I suspect that the programming code for initial setup differs from the code to enable Anywhere Access.
    Anyway, the recommendation stands: do another Factory Reset, get Anywhere Access working, and leave it enabled.
  • schumaku's avatar
    schumaku
    Afraid my dear friend sjw70​, I'm more than a little bit lost here. Don't own a Netgear Orbi 870 system - so can't test and compare) - nor any other active Orbi system. Would be nice if some other Orbi owners can take the plunge, and temporarely disable and re-enable Anywhere Access.
    What factors are we facing here?
    1. The RBE871 / RBE870 Firmware version 10.5.20.4 and out in the field for more than one year as of writing. How likely an issue? Very low probability, there would be many more reports...
    2. The iOS Orbi App - from what I'm aware, there is no public repository or a version history easy to find. Higher probability, as Apps are updated on a regular base.
    3. Some kind of a Netgear cloud backend issue, some API not accepting the previously working credentials why ever.
    Have no personal connection to the NTGR consumer edge, and don't want to escalate this to the NTGR networking friends.
    -Kurt
  • The solution appears obvious: Factory Reset and reinstall and this time leave Anywhere Access enabled.
    Is there anything unusual about the user name? (special characters? punctuation?)
    It would be really helpful if the error message would specify the conflicting information.  My guess is that it is not the product registration that is causing the conflict.  But, without being able to see what the program is comparing, there is nothing to work with.
    The Orbi app is successfully connected to the Orbi 870, and this error message appears when attempting to enable Anywhere Access.... or
    The error message appears when trying to connect the app to the router?
    • sjw70's avatar
      sjw70
      Hi,
      Thanks for your response. The error message appears when attempting to enable Anywhere Access.
      In the meantime I did a factory reset and re-installation. After the installation Anywhere Access was enabled by default and it worked from both iPhones using 5G.
      However, after disabling Anywhere Access and trying to enable again, the same error message appears. For now, I trust it was my own registration sitting in the way, not a hack or something. I'm the first owner of the Orbi, that was why was worried as bit.
      Thanks again!
      SJW
  • schumaku's avatar
    schumaku
    What's the point trying to deregister (you can't on your own anyway!), and attempt to re-register now?
    The product registration and Anywhere Access are two independant items.
    Even if you own for example a second-hand Netgear device, previously registered to an unknon third party, you still can link it to your account, and safely use Anywhere Access. The previous owner can not access it. A de-registration is not possible, simply because of the warrany is not transferable to a new user.
    You can use as many mobile devices (iPhone, Android, ...) as you need.
    Login to https://my.netgear.com/ and check if you really use the correct e-mail address - especially in case of "smart" email platforms allowing different e-mail aliases.
    • sjw70's avatar
      sjw70
      Hi,
      Thanks for your response. The idea was to remove the registered products and reregister by enabling Anywhere Access, just to see if it would solve the error message.
      Thanks again!
      SJW
