Dazza762
Oct 20, 2025Luminary
Orbi 870 update issues
So today I set up my new 870 network. Finally got everything working and things were looking great. The wifi backhaul on the 870 is a MAJOR upgrade from the 750 I was on. While I was accessing the ...
Oct 20, 2025Guru - Experienced User
Follow this and do a factory reset on the System, you'll need to press and reset button on the RBS for 15 seconds then release since they are not connected:
Orbi Systems Manual Factory Reset Process | NETGEAR Communities
Let the USB auto sync to the RBR before starting the setup wizard. Give about 5 minutes.
Dazza762
Oct 21, 2025Luminary
I did some messing around last night and things seem to have stabilised. All satellites are currently connected. Chain look different to how the 750 used to link up but that may have been due to limits on how many satellites could be connected directly. Current chain looks like this:
- Dazza762Oct 21, 2025Luminary
- FURRYe38Oct 21, 2025Guru - Experienced User
Well yes that could be in daisy chain formation. Placement out of the RBS from the RBR is key. Also how you turn them On can effect this as well.
What is the size of the home in sq feet?
30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite🛰
