atiq14th
Sep 06, 2026Aspirant
ORBI 970 and AUTO/PUSH FW NOT AVAILABLE?
Whu NG not upload Auto Or push FW to orbi 970 latest FW? i am not good in these manually update FM , my 970 2 years warranty finished so if anything went wrong i loose my ORBI ,NG should upload auto FW option too
- atiq14thAspirant
i am unable to see AUTO upto date FW of my orbi, and i cant upload manually dont know how i only
Depending on region your in and how many NG wants to update, you may not see it immediately for AU. NG seems to push new FW out in small batches.
So you'll need to wait for it or if you want, can manually do it your self.
- FrumpyGrandpaAspirant
Please check that the automatic update feature is enabled.
(see page 77 of the User Manual: https://www.downloads.netgear.com/files/GDC/RBE973S/RBE971_RBE970_UM.pdf)
Automatic update is supposed to be enabled by default, but it never hurts to double check.
In addition, the procedure to manually update firmware is explained starting on page 78.
