mhbare
Jan 10, 2024Apprentice
Orbi 970 Constant Reboots
Is anyone else still having issues with Orbi 970 continually rebooting at random times? I have no Pixel 8 to cause problems, and I am running on the latest 9.10.4.1 firmware. I've done multiple res...
- Feb 06, 2024
Nice. I think we can call this solved. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
mhbare
Jan 22, 2024Apprentice
They have reached out and working issue with them.
ChristineT
Jan 22, 2024NETGEAR Employee Retired
Hello mhbare ,
I'm sorry to hear the router disconnect issue is still occurring. I have been asked by our engineers to bring this unit in-house for further testing. Please confirm if support is working on an RMA exchange for you. If not, let's work together to expedite getting you a replacement.
Kind Regards,
Christine
- mhbareJan 22, 2024Apprentice
I've heard nothing yet from customer support regarding RMA exchange.
Thanks,
Mike
- mhbareJan 23, 2024Apprentice
Support reached out to me this morning via message thanking me for providing some debug files, but nothing was said about a RMA to return the router.
- ChristineTJan 23, 2024NETGEAR Employee Retired
Hello mhbare ,
Thanks for confirming. We'll be in touch shortly with further instructions.
Best,
Christine
- mhbareJan 25, 2024Apprentice
Fingers crossed on this one. I loaded it this morning and things are working smoothly so far.
Mine has started rebooting again. Made it about 9 hours after the firmware update, but it's been up that long before.
I guess I'll try resetting and reinstalling again and see if that makes any difference.
I processed the RMA today. I was hoping new firmware would resolve issues, but it hasn't. Thanks for your help on this.
- FURRYe38Jan 26, 2024Guru - Experienced User
Let us now how the RMA goes. New unit should work well.
- mhbareJan 29, 2024Apprentice
There are updates to stability in all the releases so maybe it will resolve your issues. I believe my issues are hardware related, so I'm still seeing them.
- mhbareFeb 01, 2024Apprentice
The firmware update made no difference. The replacement unit is expected today after a lot of back and forth with RMA issues.
- FURRYe38Feb 01, 2024Guru - Experienced User
Ok, Keep us posted on how the RMA unit does.
The new router is set, and there are no reboots yet. Took a bit of work with support to get the satellites connected, but things seem fine so far.
- FURRYe38Feb 02, 2024Guru - Experienced User
OK sounds good. Keep an eye on it.
Check the RBRs uptime occasionally:
- mhbareFeb 03, 2024Apprentice
Mine was replaced with a new RMA unit 2 days ago, and I've had no reboots since it was replaced. Keeping my fingers crossed.
- mhbareFeb 05, 2024Apprentice
There have been no re-boots since the router was replaced with a new RMA unit. Keeping my fingers crossed. Running 9.11.0.1 firmware.
- FURRYe38Feb 05, 2024Guru - Experienced User
Good to hear. How long has it been up and running? Look at the RBR IP address/debug.htm page
Been up and running for over 4 days now.
- FURRYe38Feb 06, 2024Guru - Experienced User
Enjoy. 📡
