netcora
Aug 19, 2025Guide
Orbi 970 Horrible performance in AP Mode
Hello. I purchased the Orbi 970 Kit. I also have a asus router BT 98 Pro. The router of the orbi I configured to act in AP Mode. I have connected the lan 1 (not the 10 G of the orbit to the lan 3 of ...
- Aug 22, 2025
So when configuring static IP addresses ON devices, the IP address gets set ON the device, ie. RBR. Also this IP address needs to reside out side of the host router default IP address pool range, not with in it. And do not set a IP address reservation for same IP address on the host router. Static IP addresses only are set ON the devcie and not the host router. This is normal and standard networking practice.
This was noted in the linked configuration article about AP mode.
Distances between RBR and RBS should be 30 feet starting, nothing less.
Make sure the RBRs WAN port is used to connect to the main host routers LAN port for AP mode.
Since the Orbi system is on the same subnet as the host router, you can connect some other devices to the main host router, this is acutally preferred for most of your devices. Then use the Orbi LAN ports as needed for maybe some additional remote connections in those areas. Should be noted that for any Ethernet connected RBS should you seek this connection, the RBS need to be ethernet connected behind the RBR, and not at the host router.
Aug 21, 2025Guru - Experienced User
This is in the wrong forum area - you posted it in the ReadyNAS section, not the section for Orbi. I will move it for you.
Have you tried connecting the 970 router's WAN port to the Asus? Then see if you get good performance when you connect to the 970 wifi? Try a speedtest for example.
If you get poor performance, try turning off the ASUS wifi as a test, and see if that resolves the problem. You might be getting wifi interference, and it would to rule that out.
