Mavrech
Mar 02, 2026Aspirant
Orbi 970 issues
I recently purchased several Orbi 970 kits. One with Router and 1 Satellite and one with Router and 2 Satellites i was told that the second router would just act as a Satellite even though it had a...
- Mar 02, 2026
Thanks for your help
CrimpOn
Mar 02, 2026Guru - Experienced User
You were misinformed. (Lied to.)
The RBE971 router can never act as a satellite. It must be connected to a host network (cable modem, fiber optic ONT, ISP router) using an Ethernet cable and creates it's own WiFi network.
It could be defined with the same SSID/password as the other system, but will remain a separate WiFi network. Mobile devices will not roam seamlessly between it and the primary WiFi network.
It can be placed in one of two 'modes':
- Router Mode means that it creates an entirely different IP subnet for devices connected to it.
- Access Point (AP) mode means that it does not create an IP subnet and does not fulfill DHCP requests from client devices. All devices connected to the this system will be in the same IP subnet as the primary router that it is connected to.
If you want a WiFi system with one router and three satellites, that it what you need to purchase.
Mavrech
So, If I unplug that second router will I still be able to use the satellites that came with it even though they show a different SSID ??
