AtlasShrugged
Jul 07, 2025Aspirant
Orbi 970 Not resolving IP's
A few weeks after I purchased by Orbi 970 I started having issues with internet dropping constantly and when it is connected it was inconsistent in resolving IPs. I did a full factory reset and the i...
AtlasShrugged
Thanks for your response!
I should have been more specific in my post, LAN side, it is very intermittent connecting to web pages, they load slow or not at all. Same issue on all PC's connected to the orbi.
The ISP modem is a modem/router combo, they provide a WAN IP on port 1 for another router, which the Orbi is on.
The Mfr is Altice model # is GR140IG
I did not factory reset after the FW update, Is that typically done? Also do you have settings and load after a new setup?
The FW is V9.13.1.2 it is currently set to auto update, but I will change that moving forward.
