AtlasShrugged
Jul 07, 2025Aspirant
Orbi 970 Not resolving IP's
A few weeks after I purchased by Orbi 970 I started having issues with internet dropping constantly and when it is connected it was inconsistent in resolving IPs. I did a full factory reset and the i...
AtlasShrugged
Jul 15, 2025Aspirant
After multiple tests with Orbi support it turn out to be the IPv6.
My question is and what they couldn't tell me is why I needed to disable it to get my system to work correctly?
- FURRYe38Jul 15, 2025Guru - Experienced User
Only NG knows that. IPv6 seems to have been problematic on all Orbi systems for past several months. We've made NG aware of issues users have been seeing. All in NGs hands currently. Nothing else we can do accept for wait for NG to fix and resolve it all. If you do need IPv6, then you could use the ISP Gateway in router mode and configure the Orbi system for AP mode in meantime.
