travisinfla
Mar 15, 2024Tutor
Orbi 970 on their 1.2 gp plan and getting WiFi speeds of over 1.4
Bs using with infinity and Orbi 970 on their 1.2 gp plan and getting WiFi speeds of over 1.4
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Did you have an issue?
Not sure where you're going with this
I posted in wrong thread
Any progress on this?
- Can close this thread out I mistakenly created a thread and was trying to respond within
Another thread that the cm2000 NETGEAR modem works fine with Xfinity based on my results- FURRYe38Guru - Experienced User
Enjoy. 📡
