dkstruck's avatar
Dec 07, 2024
Orbi 970 RBE971 dropping offline since firmware update to v9.12.4.16
I updated the firmware on my Orbi 970 (RBE971) router on 5 December 2024 and it has been dropping offline periodically since the update.
  • FURRYe38's avatar
    Is this the RBR unit?
    Is the bottom LED turning on RED or PINK when this happens?
    How often is this happening?
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    How many RBS are deployed?
    • dkstruck's avatar
      dkstruck
      Tutor
      Tech support stated this morning it's a software bug. They had me wipe the config and setup from scratch. Haven't seen any disruptions but Monday will give a better indication when I have some real time applications running.
      But to answer your questions the base unit (RBE971) showed offline in the Orbi app a few times. I have 2 satellites so there is more than ample coverage for the house.
      The outages are random; both timing and duration. It kept dropping a laptop wifi connection. My wired desktop lost connectivity too.
      I haven't been checking the lights; rather I have been using the Orbi app and a desktop browser to monitor status.
      • FURRYe38's avatar
        I've found sometimes new FW updates may not work with older configurations. Can cause problems, why I usually factory reset the system and setup from scratch with out loading any saved backup configurations when I see issues like this. Something also posted about in the FW update post I usually post and pin to the top of the forums.
