electramet
Jun 25, 2025Tutor
Orbi 970 startup issues with 4 or 5 satellites
We purchased an Orbi 970 with 3 satellite and added 4 all connected through a netgear 10g ethernet switch. We noticed some issues on boot up where they may boot up as wireless, or stuck in config sy...
Sep 01, 2025Guru - Experienced User
What FW version is loaded on your Orbi systems?
There is a beta FW available that you might ask NG support about and see if this helps any. I have mine running and is working pretty good.
Noginthenog
Sep 03, 2025Tutor
I've reached out to NG to participate in the Beta program so will give that a go once given access.
- FURRYe38Sep 03, 2025Guru - Experienced User
What FW version is loaded on your Orbi systems currently?
Ok sounds good. Hope it helps.
- NoginthenogSep 03, 2025Tutor
V9.13.1.2 - latest available to me
Ok. Once in the beta, hoping the newer FW will be helpful.
See you there.
