electramet
Jun 25, 2025Tutor
Orbi 970 startup issues with 4 or 5 satellites
We purchased an Orbi 970 with 3 satellite and added 4 all connected through a netgear 10g ethernet switch. We noticed some issues on boot up where they may boot up as wireless, or stuck in config sy...
Noginthenog
Sep 03, 2025Tutor
I've reached out to NG to participate in the Beta program so will give that a go once given access.
Sep 03, 2025Guru - Experienced User
What FW version is loaded on your Orbi systems currently?
Ok sounds good. Hope it helps.
- NoginthenogSep 03, 2025Tutor
V9.13.1.2 - latest available to me
- FURRYe38Sep 03, 2025Guru - Experienced User
Ok. Once in the beta, hoping the newer FW will be helpful.
See you there.
Fingers crossed
