GerardN
Jul 31, 2025Aspirant
Orbi 970_Upload Suddenly Capped at 50mbs
Hello, I have had a pleasant experience with the 970 mesh throughout the last year - where i seemed to be getting the most out of my service providers 900/100 originally and the 900/300 about 2 m...
Jul 31, 2025Guru - Experienced User
What speed testing site are you using? Ooklas installable speed test app is recommended. Be sure to try different test site servers in the app.
Tried a different PC or laptop to compare results?
What brand and model# is the ethernet adapter in the test pc?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Is IPv6 enabled on the RBR?
Using ISP detected IPv4 DNS or custom DNS?
Any Orbi features enabled like SPC or Armor or Traffic Meter?
- GerardNAug 04, 2025Aspirant
Hi, see below answers to the queries. I should stress that it works fine without the router when connected directly to fibre box, and that i have factory rest the orbi router. This worked fine for most of the last 2 months since shifting ISP - i have only noticed the slow upload during the last week.
- I have been using ookla speedtest and the one that is accessible via the router settings.
- I have connected the PC direct to the ONT via ethernet and and in this scenario i am getting close to the max 900/300
- Ethernet adapter is Marvell AQtion 10Gbit, and i have tried multiple cables (including the one that achieves 900/300 when direct connected to fibre box)
- DNS - using ISP automatically assigned dns
- IPv6 enabled
- ORBI features Armor or Traffic Meter - not enabled (i have factory reset the orbi and issue remains)
Any help appreciated - cheers
- FURRYe38Aug 04, 2025Guru - Experienced User
Try using custom DNS and disable IPv6 as well.
Try a different PC with a built in ethernet adapter to compare results.
