iBooprofen
Apr 12, 2025Follower
orbi 970
Need help my orbi 970 router speed is slow but when i plug my ethernet to my modem to see what see if it my modem but it not the speed on my modem is at the speed i parid for. I didnt have this probl...
Apr 13, 2025Guru - Experienced User
Who is your ISP?
What is the brand and model# of the ISP modem or ONT that the RBR is connected too?
Be sure your using good quality LAN cable between the ISP equipment and the RBR. CAT6A STP is recommended.
Armor, Smart Parental Controls or Circle, IPv6, Protection Engine, Traffic Meter.
Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
iBooprofen wrote:
Need help my orbi 970 router speed is slow but when i plug my ethernet to my modem to see what see if it my modem but it not the speed on my modem is at the speed i parid for. I didnt have this problem when i first got the orbi 970 but weeks later i went from 2.4gbps down and 75 up to 9mbps down and 2 mbps up. I tried everything i know, rebooting, factory reset, unplug the modem and the router for 5min, make sure my firmware are up to date which it is (v9.12.53_1.3.24). I used the chat support on thr orbi app the get some help but even me and the associate are lost we change some seetting on the orbi site where you use your admin log in but still nothing so im here waiting for a phone from them cus that what she said to expect for the nect 24-48hrs so if anyone can help please it means alot
