jomoOKC's avatar
jomoOKC
Follower
Jun 24, 2024
Orbi 970/SimpliSafe
Is the Orbi 970 Series quad-band compatible with the SimpliSafe Home Security system, which can only use 2.4 GHz?
  • FURRYe38's avatar
    Orbi has the ability to set 2.4Ghz only for devices that need this frequency.
    Make contact with the devices MFr for help and information regarding there product.
  • CrimpOn's avatar
    CrimpOn
    Of course.  Unlike some Internet of Things (IoT) devices with poorly written smartphone apps that struggle with setup, the Simplisafe alarm system setup is accomplished by selecting the WiFi system on a screen and entering the password using the keypad.  I have a Simplisafe system connected to an older Orbi WiFi system, and the connection process was simple.
    (Having a display screen and a keypad greatly simplifies the process.)
