Dilby
May 14, 2025Guide
Orbi 971 dropping wifi on router
Recently did a factory reset due to issues of wifi devices not connecting etc. Things seem to have improved, however now observing a new problem over the past couple of days. It appears the route...
May 14, 2025Guru - Experienced User
Does this happen if you let the RBS wirelessly sync to the RBR?
- DilbyMay 15, 2025Guide
The RBS is quiet far away from the RBR, so not sure if it will be in range. I can try to move it closer to test, but worried that these kind of things change the environment and introduce different variables to the mix.
Forgot to mention in the original post that a restart of the system resolves the issue for a day or so.
- FURRYe38May 15, 2025Guru - Experienced User
Testing the RBS would be to see if the problem continues or not. Helps determine if this is a ethernet issue or RBS issue.
What is the distance from the RBR to this RBS?
What is the size of the home in Sq Feet?
What channel configuration are you using on the RBR?
Will check using a wireless backhaul.
Home is 1,900sq ft spread across three floors with the RBR on the ground floor and RBS on the top floor. Most walls are stud and floors are wood.
Distance between the RBR and RBS is about 15m
Channels are manually set after doing a wifi scan of my home and the least congested of them all
2.4GHz ch.11
5Ghz ch.40
IoT 2.4Ghz only
